This is the weird part travis at caltracs gave me measurments to check out and everything is perfect he told me the rear shackle when there is weight on the suspension should be at the 6 oclock position and mine is. Its just strange to me to put the spring pad on the front hole. will it effect my pinion angle? Thanks for all the info
