You have got to remember that back in those days the front 'park' lights did not light in front on any other light switch position than park. They did not light with the headlamps when the headlamps were turned on. So don't expect them to. They turn signals are on a separate element than the park lights in front or in the rear the brake/turn signals operate on the same element but the tail lights use a separate element.
