All the new r3's look like resto blocks. Forget the cheap aspect of it all though, you more than likely will break the bank . for complete, ported W series heads and t&d rockers you are looking at 5K alone (includes buying the heads and NEW rockers). 2500~ish for a block, and 48* roller cam with offset lifters are a ton. Not to mention the custom headers and pistons.
