The main thing with a flat tappet is to run a high zinc oil and break it in correctly... 2000+ RPM for 20 min. With that, I believe the MP cams are OK.
For lube I run Rotella T + STP. It has worked well, is available and cost effective. There are lots of other good oil solutions.
