Nacho,
I saw your post and voted for the minimum CR... which may still be too high depending on cam/quench as one comment suggested. At the same time, I know a race car with 160 stat, hood scoop, hot cam and cool down time between rounds can go a lot higher. It depends a lot on quench, cam and application of the engine.
As posted above, some more info from the OP would help.
