Quote: I run Schumacher Tri-Y headers. Easy install. Doesn't trap starter. Easy access to plugs.
neat...what size diameter ? I may have to compromise diameter if the starter is accessable for change
this is your post, so yes you did ask about them and were willing to compromise in size so pound sand. Here's an answer for you: NO 2" Header is going to be and easy fit, they will have clearance issues with plugs and the starter. I suggest you ask an engine builder what size tube would be appropriate for your build. Good luck.
