Ok, my next question, is how and where does it neck down to a single plug for the motor connector.
Switch has 3 plugs, B+ in and 2 seperate B+ outs, depending on speed selected.
Yet the motor itself has only one single spade connector.
I have a wiring harness schematic for a Fury and it shows a diode/resistor in the circuit ?
Not sure I understand why one circuit would not feed both circuits regardless of which speed is selected
here's some pics of that type wiring I once had. There's a splice in it; follow the black wire at label CW, splice is at 7 o'clock position. The splice was before the wire entered trunk.
