I had a similar problem on a bone stock 5.2 Magnum engine in my Dakota. Put a new Comp Cams timing set on it, never ran after that. Moved across country, played around with it for a while and finally decided to check cam center line. Same thing, dot was three teeth off on the cam gear. EFI engines luckily wont run like that, LOL
