I’m back to the E-85 / E70 question. None of the stations in my area, six stations in a 50 mile radius, has E-85. Yep it’s a supplier issue. The supplier only sells the E-70 blend. Am I right in saying E-70 runs leaner than E-85? That tells me I need to jet up a size or two. I am also ordering an O2 sensor so I can get this thing tuned right. Jim can you post the recommenda lombda numbers again.
