48 degree is well worth a grand.
Sounds like you want a low RPM engine grunt engine.
no, why do you say that? that is why i would choose the bigger bore over the stroke
that many inches even with an indy head is going to lower the power band down somewhat.my old w5 motor was pretty much done at 7000rpm even at 422 inches, i suspect it made peak power at about 6700-6800rpm. With pump gas you obviously will have a smaller camshaft than something with 13 or 14 to 1 compression. 440 inches on pump gas with indy heads should make its most power probably around 6500 imo.
Oh, i see what your saying. Hell, i saw a set of 360-1 heads on quicktrees motor and those ports looked huge to me. as a matter of fact, at a PRI show, quicktree started cracking up, and i was like what are you laughing at, he said look how small those bb ports are. he was pointing at EZ heads
anyone know how Quicktree is doing?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
