If you are running a A-body with 70 and up aluminum water pump you can't use the stock fan shroud. And the upper water neck is close to the centerline of a mechanical fan. So you will need a fan 2" smaller diameter than the MP fan package if you want a mechanical fan. And you'll need to make your own shroud.
