Wow, it's been a while but IIRC, you have to back off all the rocker arm adjusters one at a time so you can pull the pushrods out. Now that you have no pressure on the rocker arm shaft, you pull the locking bolt out and slide the rocker arm shaft out the front of the motor. But this is from memory, it's been 25 years since I worked on a poly anything.
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
