Thanks for the reply. What does the dist solenoid accomplish? I guess it retards the timing @ idle, but for what purpose, improved gas milage or better driveability? If the carb solenoid is removed, what changes as far as adjustment? Should I make a bracket to have something for the idle screw to rest on? Thanks again!
P.S. - What would those be worth? Complete single point dist. with solenoid and carb solenoid.
