..............' the dang thing went 10.83 @ 122 mph! i couldnt believe it!"
Of course it did. It's got a Racer Brown cam! Be carefull w/ overrevving, the same thing that makes that cam run hard will help it to self destruct. (Agressive lobes) I believe max recomended rpm is around 6500. What rocker ratio(int & exh) you run w/that?
Yeah, it's got a smallblock.
