Thanks again. GTXKEN is that all you need to run is a positive from the alternator to the fuse box and I assume a chassis ground then wire it as you'd like? Does anyone know what cars use Bosch style relays? That all I really know how to use I am not opposed to learning something new but if possible of like to stock to what I know. Also with my car having the battery up front any mounting ideas?
