We pulled the frame out of my panel the other day, parked it next to the 94 Dakota frame we are going to use. The panel frame is mostly flat, where the Dakota frame dips down under the cab. Has anyone used a Dakota frame under a panel? Looks like we will have to use the front sub under the panel frame (prob not) or channel the floor under the wood section of the body to get it to set low enough. Any ideas?
