Instead of sinking money into the open chamber heads, you may want to spring now for an upgrade to Magnum heads. The Magnum heads flow much better, and the closed chamber design will pick you up about a 1/2 point or so of compression (maybe a little more on a 318).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
