Did the location of the block change when they went to the big bolt pattern??
Dan.
No it changed in 1970 , as stated there were no A body large bolt pattern rears except maybe on the 68 SS cars .
I have a 70 up rear apart in the basement, the bolt hole for the Tee is approx. 15.75" from the surface the backing plate bolts to.
Erik , the rear you have is definitely the early rear ... sorry
