Use a nib file first to remove most of the bugs and any other large raised imperfections.If you try to use sandpaper only to remove large dirt,etc.,you will most likely sand through the surrounding area. After the file is used follow through with the wet sanding and buffing as stated above.I thought the boat was going to be a C -body!
RT
