if your using the high pressure carter fuel pump check the pressure. they're usually around 8.5-9 psi. the aftermarket vapor seperator will reduce pressure some due to the large return orfice. you might be o.k. but i'd check anyway. do you know how to check and see if the kill bleeds are blocked?
