So I am in the midst of an intake swap...I go to switch my water neck and it does not fit!!!
The Performer RPM states that it accepts 1975 and earlier waterneck only, I guess mine is a later one, the Torker which I am swaping out has provisions for both.
Anyone know the best place to pick one up???
I assume the correct thermostat, which alos does not fit, will be for any pre 75 mopar.
Thanks,
Jason
