Quote: YES, you are looking for 10PSI/1K RPM typically....I think you are fine with 15-20 at idle...some setups might show more, etc....but this should be fine.
Can you tell regarding your engine what the bearing clearances were like? Loose or tight side?
Not sure about the bearing clearances. I do know the builder and the shop have a GREAT reputation! Thank!
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
