Spread bore carb will give you the "Big sucking sound" you like. Depending on what intake you have, you may be able to make it work. LD340 intakes (maybe others???) were made "as cast" for square bore carbs, but they also cast the flange area with enough extra meat that it can be hogged out to work properly with a spread bore carb.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
