4.56 gear and 29.5" tire?! Woohoo!
Alright Vic, I gotta ask, what's the comment mean? Too much gear?
I think it's a little much but, at 131.5 MPH, you are probably less than 7200 RPM. I know Bill Hart runs the same tire and gear and Lonnie used to run 4.88's with 32" tire.
I guess I really can't point any fingers in the tire/gear department.
You definetly won't need the 2:74 1st gear! I don't.
I had 5.13's with a 29.5 tire with a 340. Shifted at 8000 went through the lights at 8100. But I had W5 heads too.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
