C should be the supply
D should be the return
Upper holes in waterpump housing supply the heads
Lower holes in waterpump housing collect water from the block
Passenger side inlet from lower hose is common on C barges and is used in BB swaps when using an A engine radiator.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
