About how much power can you make with a stock small block? before you push the bottom end out of it
it's a 71 stock block 340 stroked to a 416 steel crank h beam rods all arp studs holding it together 2 bolt main
i had a 1968 398 w2 combo 13 to 1 620ish hp and it cracked the cylinder wall at 200 passes, fixed it and it cracked again in 40 passes.. i"m just sayin...Now R3
