If it is in a car or truck - Jack up the rear of the car and turn one wheel - If the other side turns the same way the same speed it is a sure grip, if you turn one wheel and the other don't turn or the other rotates the opposite direction it is not a sure grip If it isn't in a veicle ook at this. http://www.moparts.org/Tech/Archive/axle/13.html
