Rebalance over 10 grams of piston weight? #3311100
06/12/25 07:28 PM
06/12/25 07:28 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Old Mahle pistons are +.030 overbore and came in at 515 grams. After an unscheduled disassembly, I had to go with +.055 pistons that are exactly the same save for they weigh 525 grams. Is this enough of a difference to worry about?
'63 Dodge 330
11.19 @ 121 mph
Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
Re: Rebalance over 10 grams of piston weight? [Re: GY3] #3311104
06/12/25 07:33 PM
06/12/25 07:33 PM
That (10 grams) is almost 1/4 of ounce, correct work scope Then times 8 on the wrist pins, correct work confused shruggy I wish I had an answer but I don't, sorry blush
How confident are you that you can do some careful weight removeable to the new ones to match the old ones? work wrench upgrin
Re: Rebalance over 10 grams of piston weight? [Re: Cab_Burge] #3311155
06/13/25 07:37 AM
06/13/25 07:37 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I bought the hemi build book from Richard Nedbal. He was and engineer from Ford for years. He’s pretty smart. He made a comment in his book about balance. I’ll try and remember the quote but I left the book at a friends house. “ 5 grams out of balance on a 4.500” bore is equal to 100 lbs at 7000 rpm”. That seems like a lot of weight slinging around that should make some difference. I know that I’m working on a hemi build right now of a motor that has been put together by someone who knew very little about precision engine building. They used a max wedge crank with the factory balance, hemi rods and heavy TRW 12.5 pistons. The owner told me he mixed AVS gas and premium when he put gas in the car. He did not put many miles on the car on the 25 years this motor was together. Probably between detonation and the out of balnce, it beat on the mains caps. Three and four caps are loose in the block to the point you can wiggle them.
Re: Rebalance over 10 grams of piston weight? [Re: Cab_Burge] #3311161
06/13/25 09:07 AM
06/13/25 09:07 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I thought about removing a little but realized that the originals lost weight off the coating of the skirts and some carbon off the tops (I cleaned after removing).
'63 Dodge 330
11.19 @ 121 mph
Re: Rebalance over 10 grams of piston weight? [Re: GY3] #3311166
06/13/25 09:16 AM
06/13/25 09:16 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
FWIW (and I just read this for the first time myself) - https://www.enginelabs.com/engine-t...1-battling-primary-rotational-imbalance/
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Rebalance over 10 grams of piston weight? [Re: GY3] #3311176
06/13/25 10:09 AM
06/13/25 10:09 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Have the new pistons lightened on the bottom
....BAD A$$ STREET CAR.....
Re: Rebalance over 10 grams of piston weight? [Re: n20mstr] #3311177
06/13/25 10:40 AM
06/13/25 10:40 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
That is the direction I was headed.
'63 Dodge 330
11.19 @ 121 mph
Re: Rebalance over 10 grams of piston weight? [Re: GY3] #3311197
06/13/25 11:41 AM
06/13/25 11:41 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
10 gr on the recip isn't a big issue, my 2c
Re: Rebalance over 10 grams of piston weight? [Re: GY3] #3311200
06/13/25 11:50 AM
06/13/25 11:50 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
I took a paint scale and took weight off my new pistons to match the old ones. I have even welded on some new one to add a little weight to a set I had the was too light one time. I've used that old paint scale for a lot of things through the years.
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: Rebalance over 10 grams of piston weight? [Re: B1MAXX] #3311235
06/13/25 03:19 PM
06/13/25 03:19 PM
fast68plymouth Offline
10 grams of piston weight wouldn’t concern me a bit…….as long as they’re all about the same.
One piston 10g off, I’d try and even that up a bit.
10g is .353oz.
Re: Rebalance over 10 grams of piston weight? [Re: fast68plymouth] #3311298
06/14/25 03:06 AM
06/14/25 03:06 AM
Washington
skrews Offline
skrews  Offline
Washington
10 g on the piston is nothing to worry about
Re: Rebalance over 10 grams of piston weight? [Re: skrews] #3311537
06/15/25 08:43 PM
06/15/25 08:43 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Thanks, guys, I appreciate the feedback!
'63 Dodge 330
11.19 @ 121 mph
