My Luck is not Improving #3177493
09/23/23 01:46 PM
09/23/23 01:46 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Went to TNT and this happened on the first pass....
'70 Cuda,...605 Hemi Street Car (6.20 best pass, 1.33 60ft)
Re: My Luck is not Improving [Re: Dragula] #3177511
09/23/23 02:27 PM
09/23/23 02:27 PM
gregsdart Offline
gregsdart  Offline
Hard to tell, backfire and fire? Any serious damage beyond what can be seen?
Re: My Luck is not Improving [Re: Dragula] #3177519
09/23/23 03:15 PM
09/23/23 03:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So is the scoop half installed or half gone, using the proverbial glass half full metaphor. stirthepot
Re: My Luck is not Improving [Re: jcc] #3177524
09/23/23 03:54 PM
09/23/23 03:54 PM
Dragula Offline OP
Dragula  Offline OP
Just a normal pass..no back fire....hood is fixable. I have another hood I will put on for this coming week.
Re: My Luck is not Improving [Re: Dragula] #3177530
09/23/23 04:15 PM
09/23/23 04:15 PM
K
Kiddart Offline
Kiddart  Offline
K
Maybe a bigger hole in the hood. if you are really hauling the mail the air has nowhere to go so something has to give
Thank you
Kiddart
Re: My Luck is not Improving [Re: Kiddart] #3177535
09/23/23 04:29 PM
09/23/23 04:29 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Well, on the bright side, if you got crossed up enough on the big end, it would still be effective. eek
[img]http://i.imgur.com/boeexFms.jpg[/img]
31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
“Never argue with a fool; onlookers may not be able to tell the difference.” – Mark Twain
"Stay away from negative people. They have a problem for every solution."
Re: My Luck is not Improving [Re: Hemi_Joel] #3177548
09/23/23 05:59 PM
09/23/23 05:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My first thought was adding holes in the rear to allow some of the air a path out?
https://board.moparts.org/ubbthread...37060/opening-in-back-of-hood-scoop.html
Re: My Luck is not Improving [Re: Neil] #3177553
09/23/23 06:15 PM
09/23/23 06:15 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Remind me not to stand close to you in a thunderstorm.
Re: My Luck is not Improving [Re: quickd100] #3177557
09/23/23 06:29 PM
09/23/23 06:29 PM
pittsburghracer Offline
When you race stuff happens. That’s minor and not worth a second thought.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: My Luck is not Improving [Re: pittsburghracer] #3177595
09/23/23 08:02 PM
09/23/23 08:02 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
I would be looking for better quality scoop manuf.
Re: My Luck is not Improving [Re: d-150] #3177615
09/23/23 09:19 PM
09/23/23 09:19 PM
Dragula Offline OP
Dragula  Offline OP
Well at least it did not go thru the windshield this time..
Re: My Luck is not Improving [Re: Dragula] #3177657
09/24/23 05:22 AM
09/24/23 05:22 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Or anyone elses. eek
Re: My Luck is not Improving [Re: redraptor] #3177906
09/24/23 08:01 PM
09/24/23 08:01 PM
WNY
Moparrob68 Offline
Moparrob68  Offline
WNY
Well you should have expected that after it was 1/4 of the way off after your pass last week. Did you run out of Gorilla glue?
Re: My Luck is not Improving [Re: Moparrob68] #3177912
09/24/23 08:08 PM
09/24/23 08:08 PM
Dragula Offline OP
Dragula  Offline OP
Apparently the Gorilla Glue is not strong enough....
Re: My Luck is not Improving [Re: Dragula] #3178164
09/25/23 04:56 PM
09/25/23 04:56 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Probably a good indication that if you ran the formula for hood scoop size vs engine demand you'd find the scoop is too big and creating excessive drag. Thankfully it didn't damage the windshield tho.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: My Luck is not Improving [Re: A39Coronet] #3178273
09/26/23 08:04 AM
09/26/23 08:04 AM
PA
moparacer Offline
moparacer  Offline
PA
Scoops can catch a ton of air. Years ago when I put a 440 6 pack hood on my old Duster the first pass I noticed it was bowing up in the middle bad. This was only running mid 11s. It broke the middle support. I figured it was cracked or something so the next week fixed and supported it and it broke it again.... eek
It was a hinge latch setup and the scoop caught so much air it pulled the latch setup out of the hood eventually. Had to pin it down.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: My Luck is not Improving [Re: Dragula] #3178284
09/26/23 08:36 AM
09/26/23 08:36 AM
an8sec70cuda Offline
Don't you have a cowl hood for that car? It's probably faster. stirthepot
CHIP
'06 GMC 2500HD LBZ Duramax
Re: My Luck is not Improving [Re: Dragula] #3178294
09/26/23 09:27 AM
09/26/23 09:27 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
A minor Oopsie.
A mere flesh wound.
Rich H.
Esse Quam Videri
Re: My Luck is not Improving [Re: an8sec70cuda] #3178310
09/26/23 10:07 AM
09/26/23 10:07 AM
Dragula Offline OP
Dragula  Offline OP
Cowl hood is back on it....At least as long as I remember the hood pins. Mean while, I am looking for a more original looking six pack scoop, maybe even a little shorter. I think I can save the hood itself, and bond another scoop on it.
Re: My Luck is not Improving [Re: an8sec70cuda] #3178443
09/26/23 04:59 PM
09/26/23 04:59 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I have a 5" T/A I'm looking to replace with a cowl hood in the near future. stirthepot
