interesting new engine design #3175679
09/16/23 04:23 PM
09/16/23 04:23 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Do you think it will make it into major production? https://www.msn.com/en-us/autos/new...2e05ce281940b6aebc6d975e239393&ei=59
Re: interesting new engine design [Re: stumpy] #3175698
09/16/23 06:41 PM
09/16/23 06:41 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The way to gauge if it will be successful is to watch the reaction of the EV promoters. If they are silent, they don't view it as a threat. If they start attacking it tooth and nail, then yes, it has promise as it could invalidate much of their agenda. This is NOT meant to be political, just realistic.
Re: interesting new engine design [Re: 6PakBee] #3175702
09/16/23 07:00 PM
09/16/23 07:00 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
LINKY directly to engine
It looks promising, but I question the acceptance of 160 torque and 170hp. Look at how many vehicles running around now with 300 or more horsepower and enough torque to rip your head off. Unless it produces insane MPG numbers will the American consumer be ready to go back to ho-hum again? This seems more suited for the European market.
twocents
John
Re: interesting new engine design [Re: SattyNoCar] #3175710
09/16/23 07:40 PM
09/16/23 07:40 PM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
twocents
Per the article you linked - "Two modules make for 31.8 kg (70 pounds) (total weight), output of 320 horsepower and 340 pound-feet (460 Nm). Just to put things in perspective, Toyota’s 2JZ GTE engine makes 330 horsepower in its most powerful factory trim and weighs in at a whopping, by comparison, 269 kg (592 pounds), while BMW’s B58 engine has a dry weight of 139 kg (306 pounds)." 320 hp from an engine weighing less than two bags of cheap kitty litter is pretty impressive.
Re: interesting new engine design [Re: Jer] #3175728
09/16/23 10:07 PM
09/16/23 10:07 PM
SattyNoCar Offline
SattyNoCar  Offline
twocents
I skimmed too fast. I quoted single module, you quoted dual module. Dual is more impressive. My bad. blush
John
Re: interesting new engine design [Re: SattyNoCar] #3175747
09/16/23 11:04 PM
09/16/23 11:04 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Any indications on the concepts fuel efficiency? As I recall that was also an issue with mazda's rotary. If one looks at some of the 4 bangers currently being offered some are downright anemic, even the turbo'ed ones. Not all but several. Think Geo Metro with an automatic and A/C 🤣. Well, maybe not quite that bad but pretty feeble. one of my favorite cars from the 80's was the 83- 86 or so Mazda 626. 1600cc's with a 5 spd. Comfortable even on a long trip. My 85 turned 39 MPG running 75-80 MPH with the A/C on. Was even carbureted. I'd buy a new one in a nano second. Love to see this come to fruition up
Re: interesting new engine design [Re: TJP] #3175830
09/17/23 01:59 PM
09/17/23 01:59 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
has the potential to run on hydrogen fuel
you can run any IC engine on Hydrogen. Problem is it is dangerous to transport and highly flammable(bomb on wheels). Problem isn't the engine the fuel to run it is.
Re: interesting new engine design [Re: Moparite] #3175868
09/17/23 05:49 PM
09/17/23 05:49 PM
SW CO
HemiSportFury Offline
SW CO
No discussion in the article on emissions. NOx could be a deal killer. If not they will come up with some other excuse. It's still an IC and all ICs are bad.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: interesting new engine design [Re: SattyNoCar] #3175924
09/17/23 09:59 PM
09/17/23 09:59 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
twocents
If two is good, four would be even moar better. 140 pounds, 640 HP. Ooooooh.
Re: interesting new engine design [Re: SattyNoCar] #3175950
09/18/23 05:28 AM
09/18/23 05:28 AM
USA
3
360view Offline
360view  Offline
USA
The article curiously avoids giving hard numbers on compression ratio and thermal efficiency, and instead emphasizes high maximum power from a small size foot print, similar to two stroke engines.
Perhaps the very high supercharger pressures are due to inherent compression ratio limitations.
Turbine engines have high max power from a small package with smooth vibration characteristics,
but so far have not exceeded the very best thermal efficiency a piston engine can reach.
It might be deliberate “misdirection” by the article authors to not compare this design to a same size/same weight modern turbine.
Automotive engine manufactures have long complained that aircraft turbine engines can legally emit far more NOx.
Perhaps we should stay silent about this
or we might see cruise missiles fitted with catalytic converters?
Re: interesting new engine design [Re: stumpy] #3175959
09/18/23 07:57 AM
09/18/23 07:57 AM
Virginia
BSharp Offline
BSharp  Offline
Virginia
For any headline written as a question, the answer is almost always "no".
Re: interesting new engine design [Re: 360view] #3176200
09/18/23 10:57 PM
09/18/23 10:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by 360view
Perhaps we should stay silent about this or we might see cruise missiles fitted with catalytic converters?
🤣🤣 up
Re: interesting new engine design [Re: Moparite] #3176237
09/19/23 08:09 AM
09/19/23 08:09 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
lol
bomb on wheels
Just stop. In use, gasoline is more dangerous.
Re: interesting new engine design [Re: 360view] #3176330
09/19/23 02:20 PM
09/19/23 02:20 PM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
I was kinda wondering the same thing, I thought to myself "is it limited to 3 to 1 compression so they have to run 100 PSI of boost?"
