Re: The end of an era...
[Re: n20mstr]
#3153257
06/21/23 08:17 AM
06/21/23 08:17 AM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
Good luck in whatever makes you happy . We all get attached and hate to see them go , but like Al said , the memories are forever yours , and if it went to a good home there will be plenty more good times to come and be made ! x2. Glad it went to a good home, and even with the car gone now you'll always have the memories!
[Re: Al_Alguire]
#3153366
06/21/23 04:56 PM
06/21/23 04:56 PM
Posts: 20,158 PA.
pittsburghracer
I got a Camaro you can drive anywhere and still go fastish in A what????????
[Re: tboomer]
#3153559
06/22/23 12:35 PM
06/22/23 12:35 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
I got a Camaro you can drive anywhere and still go fastish in I have seen the quality of your cars Al! I'm not spending more than what my house is worth on a car! You have some bad azz machines! The good news is I have never really done the car justice. Mechanically it is done well. But the paint and body have a 23 year old Maaco paint job on it. Its still look ok but not great. I have been buying up all the parts and pieces to redo the paint and body but just never seem to get around to it. Pump gas 540" BB with a TH400 and gear vendors. We used to drive it to the track runs 9's and drive home. Its now a 10 second car but can still drive it anywhere on CHEAP pump swill. Only 9-1 compression. Also has AC but the evap was leaking and removed. Oh yeah a 68 it is.
[Re: pittsburghracer]
#3153561
06/22/23 12:37 PM
06/22/23 12:37 PM
Al_Alguire
Las Vegas
I got a Camaro you can drive anywhere and still go fastish in A what???????? 68 to be exact.
[Re: tboomer]
#3156013
07/01/23 06:13 PM
07/01/23 06:13 PM
Hopefully it ends up with someone who will give it some regular use.
