Re: 1966 B body steel wheels for hemi car
[Re: A12]
#3149234
06/06/23 09:25 PM
06/06/23 09:25 PM
Posts: 21,397 It's a dry heat
gtx6970
It's a dry heat
Im sure thats correct. A friend of mine has a stock pile of NOS steel wheels. And before he starts liquidating. I want to go thru and make sure none are the wheels I need. Some in the pile have OE part numer tags/labels. Most do not . And Im pretty sure they are a 14x5.5 inch and would take the large center cap ( my car uses the full wheel cover )
I have some 14x6 wheels I got cheap I would use if I ever decided to put it back to outward stock appearance (not likely ) and wasnt really looking for the correct rim. BUT,,,,,,,, if he happens to have them ( with my luck not likely ) BUT,,,,just in case he does. I want them
[Re: dragon slayer]
#3149331
06/07/23 10:21 AM
06/07/23 10:21 AM
Posts: 171 louisiana
musclecarman15
louisiana
early cars came with 5.0 and then 5.5...check buildsheet....14in.
[Re: musclecarman15]
#3149432
06/07/23 03:39 PM
06/07/23 03:39 PM
gtx6970
It's a dry heat
early cars came with 5.0 and then 5.5...check buildsheet....14in. Sbd is April 1966. I don't have buildsheet for the car
[Re: 6bblgt]
#3149863
06/08/23 10:57 PM
06/08/23 10:57 PM
cudaman1969
fredericksburg,va
I’ll take a picture of original rims from my 66 Hemi car tomorrow. Painted silver just like car. The little holes were a hold over from when there was a small stud to line up wheel using studs that screwed into axel instead of a lug nut.
[Re: gtx6970]
#3151488
06/14/23 01:40 PM
06/14/23 01:40 PM
cudaman1969
fredericksburg,va
The stock 66 14” wheel wont accept the small dog dish hubcap also no 15” was made for that cap.
[Re: cudaman1969]
#3151990
06/16/23 10:06 AM
06/16/23 10:06 AM
Posts: 3,134 tennessee,usa
mattsmopars
tennessee,usa
The stock 66 14” wheel will accept the small dog dish hubcap later won’t, also no 15” was made for that cap. I may not be following you , but the 66 wheels use the larger 67-back style dog dish cap. 1968 was the first year for the smaller diameter caps. Matt
[Re: mattsmopars]
#3152220
06/17/23 07:33 AM
06/17/23 07:33 AM
cudaman1969
fredericksburg,va
The stock 66 14” wheel will accept the small dog dish hubcap later won’t, also no 15” was made for that cap. I may not be following you , but the 66 wheels use the larger 67-back style dog dish cap. 1968 was the first year for the smaller diameter caps. Matt Yes I read my post…totally got that backward! New centers that use the bigger cap are made for 15” rims plus they’ll do the whole wheel too.
