Re: Damaged cylinder head repair
[Re: carnut68]
#3084301
10/08/22 01:13 PM
10/08/22 01:13 PM
Posts: 201 Texas
Chief
Texas
Who to use in central Texas area for head and block weld/repair? I've been jacking around since March to get mine welded up after dropping a valve seat on the dyno.. It's been sitting in 2 different machine shops and all they done is walk around it.
Dave Covey
[Re: Chief]
#3084353
10/08/22 03:34 PM
10/08/22 03:34 PM
Posts: 19,358 Las Vegas
Al_Alguire
Las Vegas
Call Slawko, not in Texas by any means but can fix you up. Assume Indy is still doing this work but not sure....
[Re: Al_Alguire]
#3084398
10/08/22 07:09 PM
10/08/22 07:09 PM
Posts: 3,159 Md.
carnut68
Md.
Call Slawko, not in Texas by any means but can fix you up. Assume Indy is still doing this work but not sure.... Yes Indy is. I talked to Deanna. She said send repairs Attn to her.
America First!
[Re: Chief]
#3084663
10/09/22 09:20 PM
10/09/22 09:20 PM
Posts: 3,159 Md.
carnut68
Md.
This is what I'm talking about. Dropped valve seat did this on 4th dyno pull. Dave I'd say I got lucky compared to that. Hope you get it fixed.
America First!
[Re: carnut68]
#3084818
10/10/22 01:05 PM
10/10/22 01:05 PM
Posts: 201 Texas
Chief
Texas
Thanks Carnut, So far it has been in 2 different shops that promised to get it done. Stuff just sits in the floor while they walk around it to work o other stuff. I bought another Indy block, but I'm going to use my B1 heads on it since I have them. Now I have to order a set of pistons for the B1. Wierd bore at 4.400.
Dave Covey
[Re: carnut68]
#3103584
12/19/22 01:36 PM
12/19/22 01:36 PM
Indy did the repair portion of this job, then I touched up the valve job and opened the ports to MW size.
Looks like they’ll be able to race another day......
[Re: fast68plymouth]
#3103591
12/19/22 02:06 PM
12/19/22 02:06 PM
Posts: 3,159 Md.
carnut68
Md.
Looks like they’ll be able to race another day...... Excellent as always! Yeah.
America First!
