Re: Can a headliner bow be flipped without...
[Re: topside]
#3042773
05/16/22 11:56 AM
05/16/22 11:56 AM
Posts: 19,342 north of coder
moparx
i read the post you had in the general section about selling your hemi car, then the guy whining about stuff to get money back, including the headliner bow being upside down. if that were truly the case, the headliner would be bagging down severely at that bow. having installed several headliners over the years, i can't begin to imagine how this could be possible without ripping the listing sleeve from the headliner and causing damage. this could happen during installation of the headliner, but once installed with the bows positioned as they should be, it would be real hard to do without damaging the headliner. just my experience. your mileage will vary.
[Re: topside]
#3042775
05/16/22 11:59 AM
05/16/22 11:59 AM
Posts: 27,453 So Cal
autoxcuda
So Cal
That's a weird one ! A photo might help, but: The bows are in sleeves above where the seams are, so the risk is separating the seam or tearing the material. Seems to me you'd have to drop the headliner back to the problem area to flip the bow. Probably easier to work from the front than the rear. I agree. A sleeve came apart that holds the bow, but the headliner stitching is still fine. My headliner I installed in 1995 is separated. It looked a little low and when I pushed up on the seem I can feel a distance between the seem and bow rod that shouldn't be there. Not very visually noticeable. But if I jerked around with it and wasn't careful maybe the bow would flip down . If you poke around like an idiot, you can find a way to screw anything up.
[Re: Schultz62]
#3044438
05/22/22 09:10 PM
05/22/22 09:10 PM
Posts: 16,473 On the run…
BloFish
On the run…
Yeah, I’m thinking it was flipped when initially installed.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3045478
05/26/22 09:39 PM
05/26/22 09:39 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Yeah, I’m thinking it was flipped when initially installed. I think you are right. Anyway to take down headliner without a disaster?
