Re: Axle Choice??
[Re: wkroncke17]
#3042700
05/16/22 08:14 AM
05/16/22 08:14 AM
Posts: 10,009 MN
JERICOGTX
MN
For a budget type build, Moser makes a decent axle. My only suggestion is to upgrade to 5/8 studs while you are at it. The little extra that it cost, is worth it in the long run.
69 GTX
68 Road Runner
Re: Axle Choice??
[Re: JERICOGTX]
#3042729
05/16/22 09:38 AM
05/16/22 09:38 AM
an8sec70cuda
For a budget type build, Moser makes a decent axle. My only suggestion is to upgrade to 5/8 studs while you are at it. The little extra that it cost, is worth it in the long run. Definitely go w/ 5/8" studs now. They're easier to work with and a pain in the rear to upgrade to them later on. I like and use Moser axles. Not a fan of Strange axles.
Re: Axle Choice??
[Re: an8sec70cuda]
#3042741
05/16/22 10:20 AM
05/16/22 10:20 AM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I agree with Moser, I use and like them as well.
The 5/8" stud idea is great also but factor in your street wheels(if you have any) with that decision. It is not always as simple as drilling a wheel out to make the larger stud work.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
Re: Axle Choice??
[Re: Bad340fish]
#3042756
05/16/22 11:03 AM
05/16/22 11:03 AM
Posts: 2,902 A shed in England
Tig
A shed in England
I'll be upgrading to a 9" soon since gear sets are hard to find for a Dana 60 of late.
Re: Axle Choice??
[Re: wkroncke17]
#3042788
05/16/22 12:33 PM
05/16/22 12:33 PM
Posts: 43,007 Bend,OR USA
i'm going to ASSUME it has a 8 3/4 rear end in it now, correct? If so does it have a steel cap on the driver side? If not get one soon Mark Williams and Strange engr. should both offer them I've seen way to many stock iron caps in multiple pieces after failing, NOT GOOD
Re: Axle Choice??
[Re: Cab_Burge]
#3042838
05/16/22 04:29 PM
05/16/22 04:29 PM
Posts: 2,808 Wisconsin
wkroncke17
Wisconsin
i'm going to ASSUME it has a 8 3/4 rear end in it now, correct? If so does it have a steel cap on the driver side? If not get one soon Mark Williams and Strange engr. should both offer them I've seen way to many stock iron caps in multiple pieces after failing, NOT GOOD It does have the Steel cap - Thanks Cab!!
Re: Axle Choice??
[Re: wkroncke17]
#3042919
05/16/22 09:59 PM
05/16/22 09:59 PM
Posts: 6,350 Aurora, Oh.
max_maniac
Aurora, Oh.
Has anyone used the axles from Doctor Diff? He says they're as strong as Moser/Strange.....$300/pair w/green bearings installed. Yes I'm on a budget but I don't want junk....
Thanks All!! We will find out soon. I just installed a set in my 64 Dodge wagon. 8 3/4 sure grip and should run high tens.
Re: Axle Choice??
[Re: wkroncke17]
#3042943
05/17/22 05:12 AM
05/17/22 05:12 AM
Posts: 751 Southington Ct.
turbobitt
Southington Ct.
Thanks All!! I recently bought a set for a stock length B-body Dana 60 so they are basically a stock replacement. This is a street/show car and not a race car. I couldn't tell who made them, they looked like a Chinese knockoff. The splines are much longer than they need to be probably because they blank out a common larger length axle and cut it per application. So far I have no issues but had I known I just would have paid more for the name brand axles(Moser, Strange).
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Axle Choice??
[Re: turbobitt]
#3042985
05/17/22 09:17 AM
05/17/22 09:17 AM
Posts: 3,629 Oakland, MI
dizuster
Oakland, MI
I have used Dr. Diff's 35 spline axles in my D60 now for 5-6 years. 3740lbs, Trans Brake, Radials, 1.37 60ft behind the turbo small block.
It ate a stock planetary, and rear sprag in the trans (with Low Band Apply!), but never hurt an axle.
It did bend the 1/2" wheel studs, so I upgraded to 5/8".
Re: Axle Choice??
[Re: wkroncke17]
#3042991
05/17/22 09:35 AM
05/17/22 09:35 AM
Posts: 4,651 Wichita
GY3
Wichita
Thanks All!! I have. They work very well. We use them with a spool in a 3,700 lbs. street car in a Dana 60. It's seen 1.36 60 ft. times and we beat on the car regularly. I would highly recommend getting them minus the garbage 1/2" studs they come with! We bent them as well. We put in Strange studs and all has been fine since.
Re: Axle Choice??
[Re: GY3]
#3043170
05/17/22 08:33 PM
05/17/22 08:33 PM
wkroncke17
Wisconsin
Thanks All!! I have. They work very well. We use them with a spool in a 3,700 lbs. street car in a Dana 60. It's seen 1.36 60 ft. times and we beat on the car regularly. I would highly recommend getting them minus the garbage 1/2" studs they come with! We bent them as well. We put in Strange studs and all has been fine since. 30 or 35 spline spool? Any difference in strength of them?
Re: Axle Choice??
[Re: wkroncke17]
#3043292
05/18/22 12:24 PM
05/18/22 12:24 PM
Posts: 5,892 Florida
Locomotion
Thanks All!! I have. They work very well. We use them with a spool in a 3,700 lbs. street car in a Dana 60. It's seen 1.36 60 ft. times and we beat on the car regularly. I would highly recommend getting them minus the garbage 1/2" studs they come with! We bent them as well. We put in Strange studs and all has been fine since. 30 or 35 spline spool? Any difference in strength of them? There is a substantial difference between 30 & 35 spline axles. I know of at least one manufacturer that shows a comparison, but don't recall which one. FYI -35 spline 8 3/4" and Dana 60 are basically the same! But Dana 60 has the 40 spline option with 5/8" studs if that's a big concern.
Re: Axle Choice??
[Re: Locomotion]
#3043324
05/18/22 04:08 PM
05/18/22 04:08 PM
I used a set of Strange 35 spline race axles and spool in my old low ten second pump gas Duster 3450 Lb. streetcar with the original 8 3/4 rear end with coil overs and ladder bars until it ended up bending the crap out of the rear end housing: shock I was able to reuse the axles in a Dana 60 housing that I had narrowed and had the axle ends replace with new Moser ends, no problems with rear ends after that :
