Re: Predator builds
[Re: FastmOp]
#3091550
11/04/22 07:33 AM
11/04/22 07:33 AM
Posts: 114 NW Indiana
powertrip
NW Indiana
Beautiful!! What is the combo?
Re: Predator builds
[Re: FastmOp]
#3091610
11/04/22 12:42 PM
11/04/22 12:42 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
That's Nice stuff.
I just got some ole -1s I aint got one of them spinny things though
Re: Predator builds
[Re: powertrip]
#3091614
11/04/22 12:50 PM
11/04/22 12:50 PM
Al_Alguire
Las Vegas
Beautiful!! What is the combo? KB Hemi block and Predator heads, Bryant crank, Jesel belt, blah blah blah. 596" single 4 for brackets and mainly .90 racing. Should be 1130ish or so. Also freshening our 600-13(smaller version not the X or 3X) 655" deal. Should both make similar power numbers. Be interesting to see how they fair as the combos are pretty close to each other in terms of cam numbers and compression carb and both being bracket pieces. But one with a "spread port" type head and the other with a typical BBM type head albeit with a much larger intake valve and cross section. One is 69" bigger as well. We know what the 655 made before and this time it should be a bit better with not so much piston to wall and more compression. Hope to dyno them back to back and Ill share more later when they are both done. Should be an interesting comparison.
Re: Predator builds
[Re: powertrip]
#3091616
11/04/22 01:08 PM
11/04/22 01:08 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
There you go, get started on building that Drag Week motor!! I kinda jumped the shark on that already....There was a set of those heads on here complete for $6500 and if I can find them, and if the owner might be interested in some trading parts and cash, that becomes a possibility....So I did put a post in the want ads... In the meantime, I am working on a fix for my issue on the Hemiroid, and the new cam showed up I will post updates after the weekend. ....Meanwhile, I am nose deep in this thread.
Re: Predator builds
[Re: Dragula]
#3091619
11/04/22 01:22 PM
11/04/22 01:22 PM
Al_Alguire
Las Vegas
Make sure if you are chasing used Predator parts you get the post NRC stuff, the pieces that Indy now casts after Steve Gill updated the entire casting......
Re: Predator builds
[Re: CokeBottleKid]
#3207728
01/24/24 07:19 AM
01/24/24 07:19 AM
Posts: 10,019 MN
JERICOGTX
MN
So... does Indy still make these heads? Can't tell by their website it's straight out of the 90s... Yes.
69 GTX
68 Road Runner
Re: Predator builds
[Re: JERICOGTX]
#3207801
01/24/24 01:32 PM
01/24/24 01:32 PM
Posts: 4,561 Motor City
6PKRTSE
Motor City
I wanted to do Predator build initially. Decided I wanted to keep it more streetable for now and went HEMI.
Re: Predator builds
[Re: CokeBottleKid]
#3208037
01/25/24 09:26 AM
01/25/24 09:26 AM
Posts: 4,035 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
So... does Indy still make these heads? Can't tell by their website it's straight out of the 90s... There was a shop tour video on 'Youtu' around the time the Wheatcrafts bought Indy and I think I counted 7 or more pairs of raw new castings. Like Al said the later versions have casting improvements which may or may not be necessary for some milder builds IDK. Scott Brown is in partner with some guys which have a 'big' port cnc program for them FWIW.
Re: Predator builds
[Re: HardcoreB]
#3208334
01/26/24 05:19 PM
01/26/24 05:19 PM
Posts: 2,932 Finalnd, Perkele
jyrki
Finalnd, Perkele
Had my hands on an old predator headed engine that Chris Rini used to run, made by Muscle motors. Took the heads to a flow bench and they really weren't very spectacular. Sure, they were old,maybe million valve jobs etc. But still raised some thoughts. The exhaust was decent.
Plynouth VIP '67 TT IC EFI
