Quick update . We have found some issues . Biggest one is the converter is way too tight . The weather here is not getting any better so we getting ready to make some changes and get back to it after the holidays.
It has gone 145 in the 1/8 so that’s a start, G meter has shown a little over 2 . We are on the smallest nitrous jet in the plate . But it should go a little faster . All the data log wiring I did is working , so we learning a lot
Hopefully we make some progress
Thanks for all the positive comments !
Jet the nitrous
way up and it will fix the tight converter issue!
I know
Just want to see how it runs , on a little. Before we lean on it with a lot
Nice! It should be competitive then? You'd think.
Right now , i plan on concentrate on The KOS heads up races. This year there are four races and they are giving points. BUT sure i will still go to Cecil when i can to try Ultra. Its a super competitive class and right now the record is 4.43 !!! it takes 50's to go rounds.
I plan on testing in March as soon as i can. then the first KOS race is Rockingham in April
