Edelbrock RPM versus Stage 6 Exhaust Port Height
#2978688
10/26/21 06:43 PM
10/26/21 06:43 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Looking to replace Stage 6 heads with RPM Edelbrock. Any experience on if the headers will fit the same? Hooker 2" B body
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Edelbrock RPM versus Stage 6 Exhaust Port Height
[Re: 6bblFLASH]
#2978690
10/26/21 06:48 PM
10/26/21 06:48 PM
Posts: 4,008 South Park, Pa.
68LAR
South Park, Pa.
Looking to replace Stage 6 heads with RPM Edelbrock. Any experience on if the headers will fit the same? Hooker 2" B body . I run RPM’s. I tried those Hookers a while back. Real b—h changing the plugs. Other than that issue, they fit the same. Went back to my 2” CPPA’s. Sold the Hookers.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2978695
10/26/21 07:05 PM
10/26/21 07:05 PM
6bblFLASH
N.E. Ohio
Hard to get to the plug or boot issues etc...???
[Re: 6bblFLASH]
#2978766
10/27/21 12:03 AM
10/27/21 12:03 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I’ve been running the 5209 hooker 2” supercomps for 30 yrs now on my 68 b body with rpm heads. Fit good since the beginning. I don’t find plugs a problem. Not the easiest, but certainly not the most difficult. But, i did notice the newer set my buddy got for his e body were slightly diff. For one, the collector flange was clocked differently and the triangular point where a bolt goes was pointing down reducing clearance slightly. On his car, it mattered…his was lowered with hotchkiss setup so it scraped the ground here and there. On mine….no problem with the old ones from 1990.
[Re: 6bblFLASH]
#2978775
10/27/21 01:52 AM
10/27/21 01:52 AM
68LAR
South Park, Pa.
Hard to get to the plug or boot issues etc...??? . Both. Especially #8 and #6.
[Re: 68LAR]
#2978779
10/27/21 02:48 AM
10/27/21 02:48 AM
6bblFLASH
N.E. Ohio
Ok...thanks. Nervous about changing the heads....nothing seems to ever fit with changing more than bargained for. Had to modify the 5209 to fit...move 1 tube...ain't doing that again...
[Re: fast68plymouth]
#2978831
10/27/21 10:12 AM
10/27/21 10:12 AM
an8sec70cuda
FWIW I ran Hooker 5209 headers w/ Edelbrock Performer RPM heads on a 440 and didn't have a problem w/ plugs.
#2978912
10/27/21 01:33 PM
10/27/21 01:33 PM
6bblFLASH
N.E. Ohio
Thanks for the link. Hard to argue with pictures. 👏👏👏👍
