This may sound dumb but....
#2977022
10/21/21 09:41 PM
10/21/21 09:41 PM
Posts: 8,027 The Grand State of Confusion-O...
SKR8PN
1970 Cuda, 440, six pak shaker car. X race car. Mini tubbed rails moved in. no cage(removed) Where is the fuse box SUPPOSED to be located? Left side of the column up under the dash? ....If so... this car has no fuse box.....
Karma has no menu. You get served what you deserve.
Re: This may sound dumb but....
[Re: SKR8PN]
#2977027
10/21/21 09:50 PM
10/21/21 09:50 PM
Posts: 2,364 White Plains, NY
VCODE
White Plains, NY
Just above steering column to the right on the firewall
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: B1MAXX]
#2977117
10/22/21 07:28 AM
10/22/21 07:28 AM
Posts: 6,363 Abilene, Texas
fastmark
Abilene, Texas
Ebody fuse box is part of the bulk head adapter, not screwed to the dash. This is correct. The fuse box clips right onto the bulkhead connector on an ebody.
[Re: fastmark]
#2977126
10/22/21 08:17 AM
10/22/21 08:17 AM
Posts: 4,910 new berlin wisconsin
Mr T2U
as others posted. it's on the firewall where the main wire harness goes thru. with that said. it sounds like a highly modified race car. it could be anywhere the builder decided to mount it. start at the battery and follow the power wires.
perception is 90% of reality
[Re: poorboy]
#2978750
10/26/21 09:34 PM
10/26/21 09:34 PM
SKR8PN
UPDATE: I removed the drivers seat to get a better look and to better access the underside of the dash. There IS a fuse box on the firewall at the bulkhead connector, NOT UNDER THE DASH.The wiring bundles from the column and everything else was misplaced, jammed everywhere, and blocking it from view.
