Re: 1200 Horsepower options?
[Re: cuda499]
#2979196
10/28/21 10:24 AM
10/28/21 10:24 AM
Posts: 4,562 Motor City
6PKRTSE
Motor City
There are alot of single cell happy dyno's out there for sure. As mentioned the track will tell for sure. All 42 of our dyno rooms are SAE calibrated and certified for all of our OEM and prototype development we do, so I know when we dyno engines are numbers are true.
[Re: Mpetros]
#2979886
10/30/21 12:39 PM
10/30/21 12:39 PM
Posts: 19,355 Las Vegas
Al_Alguire
Las Vegas
No weight rule or minimum?
[Re: dthemi]
#2979990
10/30/21 05:59 PM
10/30/21 05:59 PM
Posts: 20,149 PA.
pittsburghracer
Don't know if I fully understand this, but if factory BS is at play, no better option than a big Ford. A thor headed ford, would dominate any manufacturer. Chevy and mope would be way behind if there is something other than just anything goes.
For a mope, I still haven't seen anything better than a good set of predators. Better than any hemi NA that I've seen so far.
I've been playing with a pair of mechanical injected blown hemis in two cars, and have let my predator motors languish. I'm building a 4.9 bs noonan and having the second frame rail added to my stratus to deal with it. My plan is to take the 660 nitrous predator in it now, and make it NA single 4 over the winter using a get'm carb. I'll post progress as it goes.
What is this class you guys are talking about called?
He has a pulling truck.
[Re: Mpetros]
#2987993
11/22/21 07:58 PM
11/22/21 07:58 PM
Al_Alguire
Las Vegas
Hemi pattern heads are a bit better some believe. We have had Slawko do both and didn't see any difference.
[Re: Mpetros]
#2988024
11/22/21 09:22 PM
11/22/21 09:22 PM
Posts: 4,205 New York
polyspheric
Hate to point this out, but the BBC and BBF (FF, 385) are not wedge engines.
Boffin Emeritus
