2000 Ram Fog Lamps #2972167
10/08/21 06:46 PM
10/08/21 06:46 PM
South San Francisco, Ca
70sixpkrt Offline OP
I need to replace my fog lamps on a 2000 Ram 1500. What is a good brand? Should I go with OEM?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 2000 Ram Fog Lamps [Re: 70sixpkrt] #2972228
10/08/21 10:00 PM
10/08/21 10:00 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
Do you have a Sport with the factory fog lights? I have a 99 Sport and the fog lights inside reflector started to fade and get dingy so I replaced them with OEM style from the after market. Looked identical and were inexpensive. Simple job. Can't believe the difference in brightness.
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: 2000 Ram Fog Lamps [Re: U code RR] #2972233
10/08/21 10:12 PM
10/08/21 10:12 PM
No Sport package. SLT factory fog lights.
4-speed
3:54 Dana
Re: 2000 Ram Fog Lamps [Re: 70sixpkrt] #2972483
10/09/21 07:33 PM
10/09/21 07:33 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I just replaced a factory fog lamp bulb on our 2004 Dakota, and got it at NAPA. It was like $8.00 for the bulb. I need to go back and get one for the other side, because the new one is so much brighter. When you pull the bulb out, it will have a number on it, and you can just match it up off the rack at the parts store.
Re: 2000 Ram Fog Lamps [Re: 70sixpkrt] #2972510
10/09/21 08:50 PM
10/09/21 08:50 PM
Alberta
440_Offroader Offline
Alberta
Rockauto has a few different brands...
Re: 2000 Ram Fog Lamps [Re: JDMopar] #2972621
10/10/21 10:24 AM
10/10/21 10:24 AM
I need the whole fog light assembly. Mine is all faded.
4-speed
3:54 Dana
Re: 2000 Ram Fog Lamps [Re: 70sixpkrt] #2972653
10/10/21 11:47 AM
10/10/21 11:47 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 2000 Ram Fog Lamps [Re: stumpy] #2972707
10/10/21 02:18 PM
10/10/21 02:18 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I replaced mine on my 96 with the identical ones the factory used. A few years and they are starting to do the same thing the originals did(heat up in the middle/melting the plastic/yellowing). I believe LMC truck still sells them. If you want quality housings/lens/bulbs(focused beam) you won't find them on ebay. Well you may but you need a specific search. You will have to retrofit them to the oem brackets. I'm sure there are plenty of different ones that will work I found these in a google search. Unfortunately the aftermarket forgets about 20 year old vehicles so no direct fit ones.
https://www.amazon.com/Morimoto-Type-LED-Projector-Light/dp/B00XA3C22S
Re: 2000 Ram Fog Lamps [Re: Moparite] #2978760
10/26/21 10:56 PM
10/26/21 10:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
https://www.nilight.com/products/ni...-jeep-cabin-boat-suv-truck-vehicles-atvs
I put these in the lower bumper opening and wired them in with my fog lamps on my 01 2500. Total game changer!! Did the mod 4 years ago. Have them pointed down enough to avoid 95% of the “high beam flash” from oncoming cars, but the night driving is worlds better. Great investment for $40 bucks.
