Steering dead spot on-center #2919690
05/07/21 02:13 PM
05/07/21 02:13 PM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
'68 Charger, power steering, firm feel steering box, but 21 years old.
Dead spot on-center is getting worse.
Obviously I'm going to look at the steering box, but is there anything else I should be looking at to eliminate the dead spot?
Thanks!
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
Re: Steering dead spot on-center [Re: YGBSM] #2919692
05/07/21 02:24 PM
05/07/21 02:24 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If dead spot means binds up in center. that usually means adjusted too tight.
Re: Steering dead spot on-center [Re: buildanother] #2919701
05/07/21 03:13 PM
05/07/21 03:13 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
What was caster set to at last alignment?
Re: Steering dead spot on-center [Re: srt] #2919802
05/07/21 09:22 PM
05/07/21 09:22 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I had the same thing. Adjusting the box took most of it out.
Other things can contribute to the slop feeling. The bolts retaining the steering box could be loose. I've seen cracked brackets on the K member where the steering box is mounted.
The idler arm could be loose or going bad. The steering coupler may need to be rebuilt. There may be at least one bad tie rod end.
Re: Steering dead spot on-center [Re: Kern Dog] #2920725
05/10/21 12:11 PM
05/10/21 12:11 PM
Knoxville, TN
Y
YGBSM Offline OP
YGBSM  Offline OP
Y
Knoxville, TN
Thanks everybody.
1968 Charger R/T
Re: Steering dead spot on-center [Re: YGBSM] #2924945
05/20/21 05:28 PM
05/20/21 05:28 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Be sure to check the connection where the steering shaft enters the adapter on the steering box. I had the problem once, one of the little shoes in there was broke.
