Re: 340 crank into 360 block bearing spacers
[Re: LSP]
#2919680
05/07/21 01:23 PM
05/07/21 01:23 PM
What will you do about the rear seal situation?
[Re: LSP]
#2919682
05/07/21 01:36 PM
05/07/21 01:36 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Anyone make bearing spacers to put a 340 crank into a 360 block?
Thanks I want to say Mancini used to sell something like that. But like Mr. Porter I also wonder about the rear seal situation.
68 Barracuda Formula S 340
[Re: LSP]
#2919832
05/07/21 10:35 PM
05/07/21 10:35 PM
Posts: 43,123 Bend,OR USA
Why would you want to do that?
[Re: moparx]
#2919977
05/08/21 12:56 PM
05/08/21 12:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks I want to say Mancini used to sell something like that. But like Mr. Porter I also wonder about the rear seal situation. if bearing spacers were to be used, wouldn't the 360 pan still be used with the 360 rear main cap ? or am i missing something ? Thats the way I thought it would be.. but as far as I know you would just use 360 seals
[Re: MR_P_BODY]
#2919986
05/08/21 01:07 PM
05/08/21 01:07 PM
Bad340fish
Tulsa OK
I think the rear main seal is what is in question.
[Re: MR_P_BODY]
#2919991
05/08/21 01:32 PM
05/08/21 01:32 PM
I don’t believe the seal surface diameter is the same between a 318/340 crank and a 360 crank(I believe the 360 is larger)....... but a quick measurement would clear that up.
[Re: MR_P_BODY]
#2920008
05/08/21 02:01 PM
05/08/21 02:01 PM
The seal has to fit the block.......and the crank.
If the seal surface for a 340 crank is .200-.300 smaller than a 360 crank..... the 360 seal won’t even be touching the 340 crank.
[Re: MR_P_BODY]
#2920017
05/08/21 02:15 PM
05/08/21 02:15 PM
I’ve never really looked into it before....... but it appears as though the 340 seal surface might actually be a larger than the 360 seal surface.
If that’s the case, then the seal surface on the 340 crank could just be turned down to the 360 size.
[Re: fast68plymouth]
#2920023
05/08/21 02:23 PM
05/08/21 02:23 PM
MR_P_BODY
If that’s the case, then the seal surface on the 340 crank could just be turned down to the 360 size. I never looked into it either but yes the crank area could be cut down to fit(I believe).. all my engines have been 340s and I never looked into the 360s(except one B and one RB engines)
[Re: Cab_Burge]
#2920220
05/08/21 10:52 PM
05/08/21 10:52 PM
cudaman1969
fredericksburg,va
The reason I milled my 340 cap so a Magnum rear sump pan will fit
[Re: Cab_Burge]
#2920247
05/09/21 12:29 AM
05/09/21 12:29 AM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Why would you want to do that? Indeed. You lose over a quarter inch of stroke with a smaller bore. A stock 360 crank will take a surprising amount of abuse. The high RPM oiling is the catch. Keep it below maybe 6800 if you don't want to redo the oil system. I put a 360 crank in a 340 and it turned into a rod bearing eating PIA.
