small block remote oil adapter ??
#2913866
04/23/21 12:15 PM
04/23/21 12:15 PM
Posts: 4,673 On the parachute mount
n20mstr
Whats a GOOD adapter for a remote filter that goes on the block ? i see moroso, canton..... Currently have a Trans Dapt and it sweats too much oil...LOL Motor is dry everywhere else.
....BAD A$$ STREET CAR.....
Re: small block remote oil adapter ??
[Re: moparx]
#2913899
04/23/21 01:00 PM
04/23/21 01:00 PM
n20mstr
is the one you are using a screw-on, in place of the filter, or a bolt on, like the through bolt used on the small block factory 90* adapter ? Screw on in place of the filter, but i will put on whatever works well. Cant tap any holes as the engine is assembled an in the car running
[Re: AndyF]
#2919643
05/07/21 11:22 AM
05/07/21 11:22 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I have been using the canton racing units. Very nice. Kinda spendy.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: AndyF]
#2922125
05/13/21 02:27 PM
05/13/21 02:27 PM
Posts: 168 San Diego
JP8
San Diego
Last one I did was fitted with adapters right into the oil passages in the block. That worked great. What filtration is that? Sandwich filter? Flat screen? How many microns and bypass or no? I will be using an Accusump and would like to know these secrets, Andy!
Instagram : @5_points_racing
[Re: JP8]
#2922183
05/13/21 06:01 PM
05/13/21 06:01 PM
Posts: 6,135 Melbourne , Australia
LA360
Last one I did was fitted with adapters right into the oil passages in the block. That worked great. What filtration is that? Sandwich filter? Flat screen? How many microns and bypass or no? I will be using an Accusump and would like to know these secrets, Andy! It looks like an Oberg filter https://www.obergfilters.com/
Alan Jones
