2011 Ram 1500 4X4 rear axle help
#2896631
03/06/21 11:06 PM
03/06/21 11:06 PM
Posts: 1,269 Way out in the sticks of Weste...
DusterDog
Can anyone tell me what all would be involved to put a 2013 Ram 1500 4X4 rear axle into a 2011 1500?? I'm looking at buying a 2011 that was hit in the right rear, bent some sheet metal, & bumper, broke the tail light, & broke the axle off at the end of the housing. The housing, & the lower control arm is bent as well. When I look at some of the local wrecking/salvage yards it seems that the 2011 model year is all by it's self as far as the axle.
I can get a complete (housing, control arms, & maybe the brake calipers) 9.25 from a local yard for a really good price.
"I've upped my horsepower, so...... UP YOURS!!!"
Re: 2011 Ram 1500 4X4 rear axle help
[Re: GarageDodge]
#2896707
03/07/21 10:46 AM
03/07/21 10:46 AM
DusterDog
I'm going to take another good look at it this week. It appears that it was an angled hit, body lines/gaps looked good at first. I couldn't see any bends, or kinks on the frame. One of my co-workers says that Mopar changed the control arm design over the years, maybe made them heavier duty?? I'm thinking that if they made the control arms/bushings bigger, I "should" be able to drill the mounting brackets???
[Re: DusterDog]
#2896850
03/07/21 07:33 PM
03/07/21 07:33 PM
Posts: 20,627 in a cattle trailer down by th...
Guitar Jones
I'm going to take another good look at it this week. It appears that it was an angled hit, body lines/gaps looked good at first. I couldn't see any bends, or kinks on the frame. One of my co-workers says that Mopar changed the control arm design over the years, maybe made them heavier duty?? I'm thinking that if they made the control arms/bushings bigger, I "should" be able to drill the mounting brackets??? Unless they are wider. I don't know, just something to consider.
