Page 4 of 4 1 2 3 4
Re: Hemi 5.7 overheating after new thermostat and air purge. [Re: KcCrown] #2855877
12/05/20 11:32 PM
12/05/20 11:32 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
pull the spark plugs and see if one looks a lot different than the others!!=head gasket
Re: Hemi 5.7 overheating after new thermostat and air purge. [Re: rhad] #2855883
12/06/20 12:03 AM
12/06/20 12:03 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
iagree
Pull one plug from each cylinder and look for signs of coolant.
Bad head gasket symptoms
Quote
White smoke coming from the tailpipe.
BUBBLING IN THE RADIATOR AND COOLANT RESERVOIR.
unexplained coolant loss with no leaks.
Milky white coloration in the oil.
Engine overheating.
Just because it doesn't seem to run bad for now doesn't mean there isn't a head gasket problem.
Re: Hemi 5.7 overheating after new thermostat and air purge. [Re: SNK-EYZ] #2855886
12/06/20 12:13 AM
12/06/20 12:13 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can have a blown headgasket and not have water in the oil.
Re: Hemi 5.7 overheating after new thermostat and air purge. [Re: stumpy] #2855892
12/06/20 01:25 AM
12/06/20 01:25 AM
Canada -- Posts: 4034 -Registe...
5thAve Offline
Doesn't care what this says anyway
5thAve  Offline
You said you drove for a few weeks before the problem started. Air would purge out on it's own long before then.
Did you fix whatever the leak was at the reservoir? If not that can be causing the problem. The reservoir with the rad cap is part of the pressurized system and if it has a leak on that part and not pressurizing properly it can cause problems.
It sounds like you still didn't bother pressure testing the system yet? Without doing that you're wasting a lot of time guessing. Same with checking for other problems people mentioned. Just because parts are new doesn't mean it doesn't have a problem.
Re: Hemi 5.7 overheating after new thermostat and air purge. [Re: 5thAve] #2855991
12/06/20 12:51 PM
12/06/20 12:51 PM
Alberta
440_Offroader Offline
Alberta
iagree
There is air entering the system somewhere. I would pressurize the system with the spark plugs out. With pressure on the system, use a borescope to look into the cylinders. You may see the leak in there. A coolant leak in a cylinder will knock the carbon off and make it look clean/newer than the rest. So note that as well while doing a borescope. It may be external as well. Use some windex or something on the top of the tank where there's no coolant. The windex will bubble where there's air leak. You might not find any leaks either. With the engine cold, it might be fine. When it's hot, it changes the growth of the metal/gaskets, and will leak then. I've pressure tested cylinder heads and are fine when cold. Wen they get to 180°, then they opened a crack. This is what I would do. Take it or leave it.
Like mentioned, new parts aren't always good parts, so don't rely on that to fix a problem. Maybe something wasn't installed correctly? Maybe something has been damaged during all the overheating the engine has encountered lately?
Re: Hemi 5.7 overheating after new thermostat and air purge. [Re: 440_Offroader] #2856001
12/06/20 12:59 PM
12/06/20 12:59 PM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
I worked on a diesel engine that had a small crack in one of the cylinders. The crack would not allow coolant into the cylinder, but would allow hot gases into the coolant passage. The engine could idle for hours without a problem. When the engine was under load (full boost) it would boil the coolant in minutes.
Re: Hemi 5.7 overheating after new thermostat and air purge. [Re: tahoechallenge] #2856225
12/06/20 07:56 PM
12/06/20 07:56 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
You need to test for combustion gasses in the coolant,also does the fan work?
Page 4 of 4 1 2 3 4
