Re: highest mileage 5.7, stock untouched
[Re: AdventurerSport]
#2857559
12/09/20 11:26 AM
12/09/20 11:26 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
219,000+ miles on my 2008 Dodge Ram 1500 5.7. I am the original owner and it is bone stock with no issues. It has had a couple sets of spark plugs and gets regular oil & filter changes.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Kern Dog]
#2858084
12/10/20 01:38 PM
12/10/20 01:38 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Not enough dumb comments...yet
Brookeville, Md
THis truck is at 354,000 miles. Original serpentine belt and tensioner, starter, alternator, water pump, power steering pump and A/C compressor. Plug changes every 40,000, trans service every 50,000. I did replace the EGR valve and thermostat. I replaced the A/C condenser fan twice. I'm on my second radiator. ummmm that belt has waaaaay too many miles on it.
[Re: AndyF]
#2886739
02/11/21 01:22 PM
02/11/21 01:22 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
I had a 2011 ram with almost 300,000 when the lifter wiped out the cam, figured whole engine would be wore slap out so I put in a rebuilt motor and when I eventually disceted the original it looked nearly new, bearings didn''t show any wear and there was no ridge in the bore just a slight wave you could barely feel, had cross hatch all the way up,%95 of the piston coating was still like new. I could have put in a new cam/lifters and got another 100,000 easily without even cleaning out the oil pan. [u][/u]
[Re: Mr.Yuck]
#2886781
02/11/21 03:10 PM
02/11/21 03:10 PM
Posts: 1,402 Central Pa
moparjim79
Central Pa
THis truck is at 354,000 miles. Original serpentine belt and tensioner, starter, alternator, water pump, power steering pump and A/C compressor. Plug changes every 40,000, trans service every 50,000. I did replace the EGR valve and thermostat. I replaced the A/C condenser fan twice. I'm on my second radiator. ummmm that belt has waaaaay too many miles on it. You've seen the vids after belts were treated with aerospace 303 right? 250k miles and looking new
[Re: cl440]
#3059958
07/17/22 03:34 PM
07/17/22 03:34 PM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
05 Power Wagon, stock 5.7, 320,000 kms. Engine untouched other than water pump, plugs and coils. Runs fine, does not use excessive oil. Change oil every 5-6,000 kms.
