Re: Rear Disk Conversion, is it worth it?
[Re: cudabitten]
#2826439
09/29/20 12:44 PM
09/29/20 12:44 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Not from what you have shared so far.
[Re: cudabitten]
#2826510
09/29/20 03:56 PM
09/29/20 03:56 PM
Posts: 30,994 Oregon
AndyF
Hey, haven't been here in a while but I am thinking about upgrading the rear brakes on my 74 barracuda from drum to disk. It has front disks.The stopping is ok, but the drums are worn and now the proportioning valve is faulty. Anyway, I was wondering if there would be a significant change in braking? The whole braking system is new except for the proportioning valve, booster, and drums.I did order some ceramic pads for the front and was thinking of replacing the rubber hoses with stainless and stopping there. Thanks. Based on some testing we did with Tim's road race car I'd say that rear discs aren't required until the car goes over 150 mph. Below 150 mph rear drums are probably a better design. The OEMs have moved away from drum brakes these days but I think they have other reasons for that. I think they use 4 wheel discs primarily because of ABS requirements.
[Re: cudabitten]
#2827459
10/01/20 04:06 PM
10/01/20 04:06 PM
Posts: 157 new haven ct
kcarfanatic
new haven ct
Hey, haven't been here in a while but I am thinking about upgrading the rear brakes on my 74 barracuda from drum to disC. It has front disCs.The stopping is ok, but the drums are worn and now the proportioning valve is faulty. Anyway, I was wondering if there would be a significant change in braking? The whole braking system is new except for the proportioning valve, booster, and drums.I did order some ceramic pads for the front and was thinking of replacing the rubber hoses with stainless and stopping there. Thanks. Fixed it for you.
[Re: AndyF]
#2867237
12/31/20 11:19 PM
12/31/20 11:19 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
This is a pretty loaded question without knowing what you expect from the car.
I had a Mustang that I ran on the road coarse. It was a 93 with factory 11" discs in front and 10" drum in the rear. Probably will stop better than any factory muscle Mopar with OEM front disc and I was pretty content with them on the street. Until I put it on the Toronto Motorsports Roadcourse. Factory brakes were absolutely cooked after 3 laps. Brake fluid boiled to a point I had no front brakes. Upgraded to 13" dual piston in the front and 11" rear. The braking power in this 3300lb car was awesome. It could go 10 laps without overheating the brakes. I could notice a slight downgrade after 10 laps but still excellent. I was tired before the brakes were. Then I road in the same car with 13 in all 4 corners. Brakes were supercar level.
After the initial upgrade from drums to small front disc. This will allow for modulation and a big improvement over stock drums but after that it's just how much do you abuse your brakes. All of this does not apply if you run tiny tires.
