Re: SBM internal oil pump pickup
[Re: LSP]
#2758148
03/31/20 08:53 PM
03/31/20 08:53 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Kevko. They have a 7.5" circle track, 8" M303-1 and 9" M307-1. https://kevkoracing.com/collections/oil-pump-pickup-tubes
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
Posting cheap tech help (CRAP) here since Nov 97, 1000's of posts, some may be good.
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Blucuda413]
#2758436
04/01/20 03:00 PM
04/01/20 03:00 PM
Dave_J
Auburn WA
I found an old pickup that was for an old Hemi fuel engine which works well. I used AN connectors and a piece of 3/4 or 1" brass pipe to connect it to the pump cover I had. The cover was out of one of the old dual pickup kits. Small block or Big block? The OP said SBM and I read that as Small Block Mopar. Using a rear sump box style oil pan, anyone besides Stef's make a SBM internal oil pump pickup that drops straight down?
[Re: Dave_J]
#2758667
04/01/20 11:28 PM
04/01/20 11:28 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I found an old pickup that was for an old Hemi fuel engine which works well. I used AN connectors and a piece of 3/4 or 1" brass pipe to connect it to the pump cover I had. The cover was out of one of the old dual pickup kits. Small block or Big block? The OP said SBM and I read that as Small Block Mopar. I got the impression that he adapted the pick up to a different pan and I like the way he was thinking. My question is , do you simply float the pick up in the bottom of the pan , or is it anchored ? I think welding a -10 male fitting to the bottom of the pump cover would open up a bunch of different possibilities. Is there a concern about the length from pump to pick up ? ( tube or line )
[Re: Blucuda413]
#2759151
04/02/20 10:05 PM
04/02/20 10:05 PM
Dave_J
Auburn WA
My home made copy of the Kevco pickup above is a bit too big of tube at 5/8's inch . I am rethinking it.
[Re: LSP]
#2763577
04/13/20 06:39 PM
04/13/20 06:39 PM
Posts: 169 orange city,FL
Demon340GSS
orange city,FL
I found this informatiom usefull as I run the long discontinued # 31390 Milodon rear sump A body oil pan that has the crossover tube for the tie rod to pass through. These used a rear drop down ( straight down ) oil pickup that attatches to the bottom of the oil pump. It also used a deep rotor kit that is no longer available!!! It has been frustrating constantly searching for parts to keep it all going. I like the looks of the Kevko pickups and wonder if they will work with my pan? If any of you members have the deep rotor kit or the pan I use I am willing to buy.... Grant Eaton
Owner of Original collector and restored original mopars from Mr Norms Grand Spaulding Dodge.
[Re: Demon340GSS]
#2763663
04/13/20 09:52 PM
04/13/20 09:52 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
I found this informatiom usefull as I run the long discontinued # 31390 Milodon rear sump A body oil pan that has the crossover tube for the tie rod to pass through. These used a rear drop down ( straight down ) oil pickup that attatches to the bottom of the oil pump. It also used a deep rotor kit that is no longer available!!! It has been frustrating constantly searching for parts to keep it all going. I like the looks of the Kevko pickups and wonder if they will work with my pan? If any of you members have the deep rotor kit or the pan I use I am willing to buy.... Grant Eaton I have the same 31390 pan, it's 11" deep now but I'm shortening it to about 8.75" deep. Also relocating the accel baffle up and putting it at a 45° angle. I don't know your application, but I'm actually going to shorten the M-72 pump gears and body by .100" for a 8000+ rpm drag race motor. I have the Kevco pickup for the 9", and it's actually a bit short at 8.5" from the block pan rail, but does clear the steering link tube.
[Re: LSP]
#2763683
04/13/20 11:47 PM
04/13/20 11:47 PM
Dave_J
Auburn WA
I found this informatiom usefull as I run the long discontinued # 31390 Milodon rear sump A body oil pan that has the crossover tube for the tie rod to pass through. These used a rear drop down ( straight down ) oil pickup that attatches to the bottom of the oil pump. It also used a deep rotor kit that is no longer available!!! It has been frustrating constantly searching for parts to keep it all going. I like the looks of the Kevko pickups and wonder if they will work with my pan? If any of you members have the deep rotor kit or the pan I use I am willing to buy.... Grant Eaton I have the same 31390 pan, it's 11" deep now but I'm shortening it to about 8.75" deep. Also relocating the accel baffle up and putting it at a 45° angle. I don't know your application, but I'm actually going to shorten the M-72 pump gears and body by .100" for a 8000+ rpm drag race motor. I have the Kevco pickup for the 9", and it's actually a bit short at 8.5" from the block pan rail, but does clear the steering link tube. Cutting and adding a section to tubing is so easy. I Mig weld thin wall tube and never have leaks. For my LRT, my new Milodon 30985 360 truck pan is 10.75 inch deep 8 qt. I am going to run 6 qt + dual 51515 filters so 7.5 qts. I did find the Kevco 9 inch pickup too short for my stock 360 truck pan and was making my own for it, but I will be sectioning the Kevco one to fit the Milodon pan. I was told that a stock oil pump using the Kevco type pickup will suck more oil per minuet than the Melling High Volume with the stock sipper straw pickup tube. The stock pickups are 3/8 pipe thread so the inside diameter is between 3/8" and 7/16". The Kevco is 5/8" ID
[Re: Demon340GSS]
#2763698
04/14/20 01:32 AM
04/14/20 01:32 AM
Posts: 11,521 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I found this informatiom usefull as I run the long discontinued # 31390 Milodon rear sump A body oil pan that has the crossover tube for the tie rod to pass through. These used a rear drop down ( straight down ) oil pickup that attatches to the bottom of the oil pump. It also used a deep rotor kit that is no longer available!!! It has been frustrating constantly searching for parts to keep it all going. I like the looks of the Kevko pickups and wonder if they will work with my pan? If any of you members have the deep rotor kit or the pan I use I am willing to buy.... Grant Eaton It has been awhile. But I seem to remember that long rotor set was used in a high volume Hemi pump or some other application. They went into a high volume housing, stuck out a quarter inch and used an aluminum cover made to fit them - made by Milodon I think. When they dried up, the only way to get them was spend the money for that pump and rob them out of it. I'll bet they re still being made and put into something. I wouldn't be afraid of modifying a stock pump housing for the right stuff if you could locate something. Seems the choices are getting to be cobble something together, go with the Titan pump or go to a dry sump.
[Re: Dave_J]
#2764221
04/15/20 12:38 PM
04/15/20 12:38 PM
cudaman1969
fredericksburg,va
I did almost the same on my 340 stocker like Dave J showed, Long story short I used the small rear sump Magnum pan, used a 3.0 liter v6 oil pickup with modifications (3/4” inside pipe with the big bell) straight down into the sump, plugged the existing stock hole. Now I can use the one piece rubber pan gasket too. Also not using oil filter, lines running to the accusump, filter is a big oil restriction like a muffler
[Re: cudaman1969]
#2764279
04/15/20 03:10 PM
04/15/20 03:10 PM
Dave_J
Auburn WA
IMHO, IF and only if I were running down the strip for say X times and then do a total teardown would I bypass running a oil filter. But my engines are 95% street driven (HARD) and I will go about 7,000 miles between oil changes using a good Dino grade 5W30 oil so it will get a 20 micron filter. I am toying with running a Dual filter and/or a 2 micron (Amesoil) 'Bypass' oiling system.
[Re: Dave_J]
#2764308
04/15/20 04:01 PM
04/15/20 04:01 PM
Posts: 604 TN
1DGEMAN
TN
Any specs on how to modify the pump cover for that style pick up? Where on the cover does one put the tube? Thanks, Rod
Real Men shift for themselves
[Re: CMcAllister]
#2764316
04/15/20 04:30 PM
04/15/20 04:30 PM
Posts: 4,457 Washington
madscientist
Washington
I found this informatiom usefull as I run the long discontinued # 31390 Milodon rear sump A body oil pan that has the crossover tube for the tie rod to pass through. These used a rear drop down ( straight down ) oil pickup that attatches to the bottom of the oil pump. It also used a deep rotor kit that is no longer available!!! It has been frustrating constantly searching for parts to keep it all going. I like the looks of the Kevko pickups and wonder if they will work with my pan? If any of you members have the deep rotor kit or the pan I use I am willing to buy.... Grant Eaton It has been awhile. But I seem to remember that long rotor set was used in a high volume Hemi pump or some other application. They went into a high volume housing, stuck out a quarter inch and used an aluminum cover made to fit them - made by Milodon I think. When they dried up, the only way to get them was spend the money for that pump and rob them out of it. I'll bet they re still being made and put into something. I wouldn't be afraid of modifying a stock pump housing for the right stuff if you could locate something. Seems the choices are getting to be cobble something together, go with the Titan pump or go to a dry sump. That long rotor kit was made so you could just drop the gears into you pump housing and drop on their pump cover/pickup and you had a HV oil pump. You can just skip all that and use a HV pump. The pickup system for that pan is very adjustable. I got very lucky. I have that pan on my street car and that’s all I’ll use if I have it. Bit of a PITA to drop the center link to get the engine out but it’s worth is. I have another pan waiting for my next build and it has the swinging pickup. It’s a shame they don’t make that pan anymore. Street guys just won’t buy them because theythink they hang too low ( I never scrape mine and it’s at OE ride height) or the center link thing turns them off.
[Re: 1DGEMAN]
#2764348
04/15/20 05:38 PM
04/15/20 05:38 PM
cudaman1969
fredericksburg,va
Any specs on how to modify the pump cover for that style pick up? Where on the cover does one put the tube? Thanks, Rod Directly opposite the hole on the other side, straight down. I can take a pic tonite if you like. On the oil filter, yep to street but race car why? The only thing that is a problem is IRON that will eat stuff up. IF you have iron you just broke something big, quickly, little particles will be the least of your problems. If you break anything it goes thru the pump first then a filter if using one but will probably bypass the filter right into your oil galleries. Lose a bearing you’re done, lose a rod you’re done, it all happens way to fast to save. Oil filters where made for DIRT getting into the carb then into engine, not stopping parts and pieces. Brass and babbit won’t scratch a crank. A drain plug magnet and one in the pan collects the fire iron dust off rings and cylinder walls (which takes hundreds of thousands of miles) Think about it awhile
[Re: 1DGEMAN]
#2764366
04/15/20 06:17 PM
04/15/20 06:17 PM
Dave_J
Auburn WA
Any specs on how to modify the pump cover for that style pick up? Where on the cover does one put the tube? Thanks, Rod I had the Kevco pickup already but I laid it on a sheet of paper and traced around and then cut it out. Then I laid that cut out over the Kevco pickup and rubbed the bolt holes and the hole for the tube. Center punched the tube's mark and drilled the 5/8's hole. Used drimel to grind the hole for a snug fit on the tubing. Then MIG welded it to the cover plate. Notice the 3/8" pipe plug in the OEM pickup location.
