1969 M Code Dart GTS motor #2716172
11/15/19 06:28 PM
11/15/19 06:28 PM
Kentucky USA
RR6BBL1969 Offline OP
Kentucky USA
I’m building my 1969 M code Dart 440 engine and was wondering if the fan was a six or seven blade, viscous or direct mount with what size spacer? The engine is a single pulley setup with no p/s or a/c. Any help is appreciated. Thanks
Re: 1969 M Code Dart GTS motor [Re: RR6BBL1969] #2716186
11/15/19 07:03 PM
11/15/19 07:03 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
7 blade with a .70 thick spacer... wave
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 M Code Dart GTS motor [Re: Rhinodart] #2716202
11/15/19 07:35 PM
11/15/19 07:35 PM
Kentucky USA
Kentucky USA
Thanks. Viscous clutch fan too? 5/8 heater hose on both sides?
Re: 1969 M Code Dart GTS motor [Re: RR6BBL1969] #2716204
11/15/19 07:43 PM
11/15/19 07:43 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No, not a viscous fan, a regular 7 blade fan with a spacer. You can look at the gtsregistry at the pictures of a 383 which is the same used on a 440 for an A-Body.
A-Body's RULE!
Re: 1969 M Code Dart GTS motor [Re: Rhinodart] #2716207
11/15/19 07:48 PM
11/15/19 07:48 PM
Kentucky USA
Kentucky USA
Thanks again!
Re: 1969 M Code Dart GTS motor [Re: RR6BBL1969] #2716252
11/15/19 11:45 PM
11/15/19 11:45 PM
Does it have the original block still?
I owned a early production(SPD of 10/21/1969) H code 1969 GTS 4 speed car, I have heard and been told that the 1969 440 M code blocks had a different driver side engine mount with the same K member as all three years the 383 A body cars had confused help
Re: 1969 M Code Dart GTS motor [Re: Cab_Burge] #2716265
11/16/19 12:46 AM
11/16/19 12:46 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Yes, due to the taller block. Basically a modified 383 A body mount.
Abe Lincoln
Re: 1969 M Code Dart GTS motor [Re: dart4forte] #2716384
11/16/19 01:16 PM
11/16/19 01:16 PM
When I first got that Dart it was missing the motor and trans but had the original BB block radiator, a se of 1 7/8 Hooker fender well headers and the original complete motor mounts.
I found a 440 block that had the correct mounting bosses on it and used it to race that car for 7 to 10 yrs shruggy
A friend of mine several years later bought a 1969 M code fastback Baracuda from a guy in Montana that had, according to the seller, the original block that had two holes drilled and tapped into the front of oil pump boss down low for the 383 mount to bolt into confused
Re: 1969 M Code Dart GTS motor [Re: Cab_Burge] #2716610
11/17/19 03:25 AM
11/17/19 03:25 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Here is the drivers side motor mount from a numbers matching 69 M-Code GTS I was working on today, see it at the MCACN show next week!
A-Body's RULE!
Re: 1969 M Code Dart GTS motor [Re: Rhinodart] #2716615
11/17/19 07:02 AM
11/17/19 07:02 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Funny. That torque strap looks nearly identical to the one on my 383 GTS. Right from the hardware store, 40 years ago.
Oh my goodness, is that a Fram filter. Probably won't make it to the end of the driveway grin
Re: 1969 M Code Dart GTS motor [Re: BSB67] #2716662
11/17/19 11:55 AM
11/17/19 11:55 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The corregated hose and the Fram went into the trash last night. The car has been in mothballs for 13 years, and is alive now!
A-Body's RULE!
Re: 1969 M Code Dart GTS motor [Re: Rhinodart] #2716735
11/17/19 02:06 PM
11/17/19 02:06 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Jim, is that your M code?
Abe Lincoln
Re: 1969 M Code Dart GTS motor [Re: dart4forte] #2716944
11/17/19 10:12 PM
11/17/19 10:12 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No, I had to sell it to one of my buddy's and I get to work on it, the story of my life... frown
A-Body's RULE!
Re: 1969 M Code Dart GTS motor [Re: Rhinodart] #2717055
11/18/19 09:40 AM
11/18/19 09:40 AM
blewbyu Offline
blewbyu  Offline
I have the correct one. will dig it out and send you the part number. It is not for sale its for my M Code car I'm restoring.
Re: 1969 M Code Dart GTS motor [Re: blewbyu] #2717157
11/18/19 01:02 PM
11/18/19 01:02 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Hey... we didn't burn the place down. You should be thankful.
Re: 1969 M Code Dart GTS motor [Re: Rhinodart] #2717176
11/18/19 01:44 PM
11/18/19 01:44 PM
That one looks like his, not what I would expect from Mopar blush
Re: 1969 M Code Dart GTS motor [Re: Cab_Burge] #2717251
11/18/19 05:32 PM
11/18/19 05:32 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
I have a fan for one of these cars I believe...in case you're looking for one. 2863213 is the number on it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1969 M Code Dart GTS motor [Re: Cab_Burge] #2717272
11/18/19 06:23 PM
11/18/19 06:23 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Don't forget that Mr. Norm made this motor mount first in 1968 and Chrysler just followed his lead. Why reinvent the wheel?
A-Body's RULE!
